New Tailwheel Bracket
Post here to sale aircraft items or place want to buy ads. Posts here will automatically delete after 60 days.
Postby N111YX » Sat Oct 22, 2011 5:33 pm
Tailwheel brackets are ready to ship! To all of you that have sent me your address, I hope to ship them Monday or Tuesday (10/24).
For more info, click here...
viewtopic.php?f=21&t=125
Kip
2000 Kolb Firestar II, Rotax 503, BRS 750, no electrical system, 475 hours
2010 Waiex 0082, Jabiru 3300, Dynon D-180, Becker radios, 475 hours, 48 states
2020 Pitts S-1D, Lycoming IO-360, building wings
Atlanta
N111YX
Re: New Tailwheel Bracket
Postby Sonex1517 » Thu Oct 27, 2011 8:08 pm
I got this awesome new tailwheel bracket today. Thanks Kip!
Now to get to the point of having an airplane to install it on.... ;)
Everything happens for a reason!
Postby 142YX » Sat Oct 29, 2011 2:53 am
Received mine in the mail today.. 20 minutes after the tailwheel from Vans showed up!
I hope to have Waiex # 142 resting on her gear very soon.
Thanks again, Kip
90% done, 90% left to go
142YX
Postby N111YX » Wed Nov 09, 2011 3:33 pm
The first 25 are gone! I am going to do one more run of 25 if anyone was left out...:)
Kip
Atlanta
N111YX
Postby Onex11 » Thu Nov 10, 2011 3:16 am
Hi Kip,
Onex also uses SNX-L03-05. I would like to get one for my ONEX. Put me on your list for the next run.
Thanks.
Rheal
ONEX plans 0021
Onex11
Postby falvarez » Thu Nov 10, 2011 7:44 pm
Hi Kip,
I'm plans building Sonex #800. I've read that some Sonex owners are happy with the cheap ($30) 5" tailwheel that Wicks sells.
http://www.wicksaircraft.com/catalog/pr ... index.html
Do you think this tailwheel would work with your bracket? If so, can you let me know how to get a hold of you to purchase one from the next batch?
Frank
Sonex #800 - currently building fuselage
Frank Alvarez
Sonex #800, Aerovee 2.1
Scratch Building (attaching wings to fuselage)
falvarez
Postby N111YX » Thu Nov 10, 2011 10:54 pm
Frank, all I can do is give you the dimensions as I have not tested that wheel. My fork is 2.100 inches wide to accomodate the Van's wheel. You may or may not be able to take up the difference with washers. The holes are drilled for an AN-6 (axle) bolt.
It's best to email me at n 1 1 1 kx (at) mindspring dot com and I will put you on the list for the second run.
Regards,
Kip
Kip
Atlanta
N111YX
Postby N111YX » Wed May 02, 2012 10:36 pm
I have more brackets in stock if anyone out there is scrapin' their tail...
Kip
Atlanta
N111YX
Postby MichaelFarley56 » Wed May 02, 2012 10:59 pm
Let me the first to say that Kip's bracket, combined with a 6" Vans tailwheel, is an excellent upgrade to the stock system. The bigger wheel gives more clearance (very much needed, especially if you're operating on grass) and the bearings are much quieter on takeoff and landing.
Waiex #0056 - N569KM
AeroVee #0631
Postby kmacht » Thu May 03, 2012 2:41 pm
Do you have a price for the bracket and what Vans tailwheel it works with?
Return to Classifieds
