by sonex1678 » Wed Oct 21, 2015 12:18 pm
Like a few others, I am at the spar mating stage for Sonex 1678. I am clear on the mating procedures (have up-drilled the alignment holes and am in the process of up-drilling the blocks, all using the drill press method), but was wondering what the latest thoughts are on the final block up-drilling of the blocks from 1/4" to 3/8"? I have the 1/4" to 3/8" Fastenal bit recommended on the forum, and intend to use it unless there is a reason not to (such as if the experience of others indicates that the resulting hole is too big, and a smaller drill/reamer is really necessary. Also, what are the thoughts on when to up-drill? Should I up-drill now (while initially mating the spars) and then use the "alternate" method described in the forum using drill guides to drill the airframe angles once the wings are installed in the fuselage; or, up-drill the blocks and the airframe angles at the same time once everything is assembled?
I appreciate any and all comments/suggestions, as like quite a few others before me, I am pretty apprehensive about this step.
Douglas B Scripture
Sonex 1678
