by sonex1678 » Wed Feb 10, 2016 8:47 pm
Sonex and Waiex folks:
After getting my first wing together, except for final riveting, I checked the flap/aileron trailing edge alignment at the neutral position (such as with flaps up, ailerons neutral) and found that the aileron trailing edge is further forward than that of the flap. I rechecked the hinge installation and both were correct. Stumped, I then checked the flap/aileron skin sizes per SNX-Z02 (my skins are factory cut and bent) and see that the aileron is about 3/16" shorter than the flap, which would make the trailing edges not align at neutral if the hinges are installed exactly per the plans. As a result, I replaced/redrilled the aileron hinge to move it rearward a little so that the aileron trailing edge would match the flap at neutral (I couldn't move the flap hinge forward since it would start to limit the flap's upper movement and might stop the flap from reaching neutral). After doing this, the trailing edges align at the neutral position; however, the upper hinge extends further back exposing more of the hinge "lugs". Sonex Tech Support indicated that it was OK to move the hinge as long as only the hinge lugs were exposed (good news) but also thought the misalignment was unusual--they checked one of their aircraft and the misalignment was less than 1/16", whereas mine was more like 3/16" (which is what my calculation indicated it would be), so I have some concern. Of course, without seeing exactly where the factory hinges are actually located, the fact theirs aligned better might just indicate that the hinges were initially drilled more like my second setup....
So to all of you who have already passed this point in their build..., am I missing something and the misalignment I had was really "unusual", or have others experienced the same thing? I tried to look at various acft photos and builder logs, but it was hard to tell what other experienced as most of the photos have the flaps down...). Also, if others have experienced the same thing, did you just leave it as is or did you go to the trouble to move the hinges somewhat to get the "perfect" alignment at neutral? It is great that everything now lines up at neutral on my wing, but the exposed hinge lugs aren't quite as attractive, and I want to be sure I am "not missing something" before finishing this wing and beginning the next....
Any and all assistance and comments will be greatly appreciated.
Doug
Douglas B Scripture
Sonex 1678
