Re: Update navworx adsb boxes
Posted: Tue Jan 24, 2017 8:10 pm
fastj22 wrote:There is only one antenna for the 1090, the Skyguard TWX Pro is only 978 out, but dual band in. You could tie both 978 (in) and 1090 (in) to one external antenna with adapters and a tee, I did this with my Stratux and it worked. They provide individual whip antennas for the in's that attach to the box. The 978 out requires a dedicated UAT and can't share the transponder one as far as I know. You must provide the UAT. I use a dedicated 978 UAT on the belly for (in) to get the best signal from the ground stations.
Thanks for the clarification for your installation. In their installation manual they show 4 antenna for ADSB (2 for each frequency; transmit and receive), plus the transponder antenna. So the installation manual appears to be calling for 5 antennas mounted outside the aircraft. The GPS is a puck on the glareshield, so nothing hanging out in the breeze.
