Direct C51 wrote:Ken, what exactly are you having trouble with? The Sonex/Waiex is about the easiest taildragger there is to fly. Perhaps you have a gear alignment issue?
gammaxy wrote:Do you live near other Sonex builders/owners? Checking the alignment isn't very difficult. Sonex provides some cylindrical spacers that go over the axles and are aligned using a straight edge across both axles to set the alignment. It would be an hour or so job to check it for someone who has done it before (due to removing the wheels and brakes). I'd expect an alignment problem to also cause shimmy.
I'd lift the wheels off the ground and twist the wheels and legs to see if there's any slop that has developed and determine whether that is causing the misalignment. My bolt holes on one leg elongated after a couple years, so I ended up removing the axles, welding the holes closed, and redrilling. Then I added shims to the leg/axle socket to remove any play.
I built a simple fuselage jack from two scissor jacks to make this type of work easy:
http://chrismadsen.org/2016/03/fuselage-jack/
Does yours have the stock direct tailwheel linkage? When it fishtails, does it feel like the tailwheel is losing traction? When I did transition training, I was over-controlling the tailwheel due to not being used to the direct control (and probably out of practice).
kenandkatie2 wrote:Yes, it does feel like it's losing traction on both takeoff and landing. I chalked it up to how small the tail wheel is. I've had about 3-4 hours of tail wheel training but am about ready to give up.
