URGENT WANTED - MGL RDAC
Postby GraemeSmith » Tue Jul 19, 2022 12:28 pm
July 19
I'm currently semi-broken down in Iowa with a part failed RDAC.
Does anyone have an MGL Avionics RDAC X Rev B mounted on a 129B connector Board.
While local flying is probable - X-Country trip home would be unwise.
401 864 1897
graeme@graemejwsmith.com
Re: URGENT WANTED - MGL RDAC
Postby GordonTurner » Tue Jul 19, 2022 4:25 pm
Hi Graeme
Can’t help you with the part. But day vfr nothing is required. If you don’t have a mechanical oil pressure and tach, you can pick up a mechanical oil pressure gauge/kit and do a temp install. Maybe the same auto parts store has something like a tiny tach as well. Should be all you need to comfortably get home, day vfr…
Good luck, Gordon
Postby GraemeSmith » Tue Jul 19, 2022 5:45 pm
Thanks Gordon. I kinda want the EGT and CHT as in this heat it is a bit finicky to get right.
Good news - thanks to the two who respondsd and units are on the way.
Case resolved.
