DCASonex wrote:Have the Skybolt fasteners on mine, with the adjustable sockets so as to use one length of stud. Many but not all of my studs are captive and that avoids any mix up. I can remove my cowl with just the tip of the nail file blade on key chain sized Swiss Army knife which makes for more frequent removal which i see as a safety advantage.
DCASonex wrote:Had to dig to find 11 year old receipt for this. Have more info in hangar but stuck home with COVID. All purchased were direct from Skybolt.
17 - # SK213-2 Receptacle 2000 series C
8 - # SK213-2D dimpled
25 - # ZG28S3-2 Skytanium TSO-C148
30 - # SK2600-LWS cloc retaining ring
1 - # SK-T26 cloc fastner tooling
1 - # Template-213 cloc fastner tool
The above being 11 years old, things may have changed a bit, bit this should get you started.
I made my own conversion from stock vertical split cowl to horizontal and used hinges to connect the top to bottom along the straight sides, but if doing it again would just use a couple of more Skybolts, spaced 5" - 6"apart.
As to the FAA failure notice, it was on turboprop planes and I have used my setup for 10 years with zero problems. Even flew once with the pins not installed in the side hinges, and was near VNE on that flight. NOT recommended, but no problem that time. I do have two Skybolts installed on each side of propeller as that looked to be a critical area. Have seen others with just one fastener each side.
Studs can be held with the retaining rings on all areas that are flexible enough to engage or disengage the fasteners by flexing the cowl. but at from corners and next to the prop, I remove them.
