sonex892. wrote:Hi Skip.
My Sonex with a Jab 3300 needs a lot of right pedal on climb out and cruise. I have tried 3 things.
Firstly an adjustable spring to add forward force to the right rudder pedal. Worked good at speed but if it wasnt released before landing things got interesting. I removed this on a weight reduction campaign a while back.
Secondly tried numerous lengths and widths of a balsa wedge. Could not get enough rudder force at speed with the wedge. For aesthetics the wedge would have been my first choice but it just wasnt good enough. If you only need a small amount force a wedge might be enough.
Third was an aluminium trim tab. This gave the best result. I still need heaps of right rudder during full power at climbout but at cruise its good. I think the tab is about 200mm long. I'll be flying in the morning so will try to remember to measure it. For figuring out the length location and bend I used double sided tape and duct tape for testing flights with both the wedge and tab. I have had the tab rivetted on for about 5 years now.
sonex1566 wrote:Hi Skip,
I used to think that it was just me, however I have seen a few others with exactly the same issue. I experimented starting with tiny and gradually growing bigger and bigger. I reckon that mine is around 7" long x 1 1/2" bent out into the airflow. If it was a model plane I'd stick a couple of washers behind the engine mount to give it some right thrust....I tried it with the Jab, but the prop drive looked stupid about an inch off centre in the cowling. If I was really motivated I would have a go making another engine mount with a few degrees right thrust but the prop still in the middle. However the cost of 4130 especially the square tube is bloody high in Australia and my motivation is rather low....The option for the time being is to stand in front of the trim tab if someone takes a picture.
builderflyer wrote:Dave Anders' fastest RV-4 example of using a Gurney flap for rudder trim
