Dave Wolfe wrote:Most aircraft need nose down trim at high speeds and nose up trim at low speeds. Yours seems opposite to that which raises my eyebrow.
As speeds go up, so do control surface forces. You are finding your trim springs are sufficient at lower speeds where control surface forces are lower, but at higher speeds the elevator aerodynamic centering forces are overpowering the springs.
You need to get the aerodynamic forces more in balance. You can add a fixed elevator trimtab that deflects the elevator upwards, or you can adjust the incidence of the horiz stabilizer by moving the leading edge downwards compared to the trailing edge.
Onex107 wrote:I would like to add two cents to this discussion. My experience is with a Onex w/ Aerovee and a nose wheel. But, I didn't like the way the tail moved around in straight and level. Elevator trim was not a problem using the Sonex system, but the tail did not want to stay in line. So I evened out the air flow on the rudder/vertical stab by adding a gap seal to the rudder hinge line. That calmed the tail down so well that I went ahead and added gap seals to the bottom of the horizontal stab/elevators also. On the first flight I had to turn the trim down about two turns to go back to hands off. I don't change the trim when landing so it was set to the previous cruise setting. I have to believe that I gained a lot more down force with the gap seals. Besides, they look a lot better too. It's very easy to do, only adds ounces of weight and if you don't like them only two rivets holds everything in place.
