Page 6 of 35
Re: Scott's Sonex #1629 - Progress
Mon Mar 24, 2014 5:57 pm
by Rynoth
Nice progress Scott! You're building mostly solo, right? How did you lift the turtledeck into position? My method started off sloppy but got the job done in the end:
http://www.rynoth.com/wordpress/waiex/2 ... eck-cleco/I like seeing current builder progress as much as past builder progress... a lot of things have changed over the years I think, and those of us building now are probably running into our own unique set of challenges. It's good to share!
Mon Mar 24, 2014 6:17 pm
by ScottM-Sonex1629
Ryan,
Funny you should ask since I was reading your post on "how did you do it?" Yesterday...
Yes mostly working solo, will get help from family if it's a big lifting task, etc. I'm a tall guy and have a pretty wide wingspan...so I ended up rotating the aft f-box on it's side, then grabbing the opposing ends of the turtledeck skin and carefully inserting the aft end in between the rear section of the longeron and skin and working my way up to the front edge. Probably took less than 30-45 seconds. I then carefully bent the skin up and inserted the opposite side in using the same technique. Once done I rotated the whole assembly back upright. Before inserting the turtledeck skin I marked the 1" depth line from the edge so I would know if the skin was in far enough or too far.
Fri Mar 28, 2014 9:07 pm
by ScottM-Sonex1629
Turtle deck and all formers are updrilled to #30 size so it's time to take it apart and deburr. Would like to have this riveted together by the end of the week(end)!
Fri Mar 28, 2014 9:26 pm
by MichaelFarley56
Looking good sir! I can't wait to see the finished product here shortly!
Fri Mar 28, 2014 11:20 pm
by Sonex1462
Looks great. You sure are making good progress!
John Stewart
Sonex 1462
Sat Mar 29, 2014 3:30 pm
by ScottM-Sonex1629
Another productive evening/day. The aft fuselage assembly is now complete! Time to move onto the forward fuselage...
Sat Mar 29, 2014 11:08 pm
Looks great. Had we not goofed on the cross tie box we would have kept right up with you. Well, maybe not! You are getting there fast!
Sat Mar 29, 2014 11:30 pm
by onexpilot
Where's the Like button?
Thu Apr 03, 2014 10:05 pm
by ScottM-Sonex1629
Fri Apr 04, 2014 7:38 pm
by MichaelFarley56
Your plane is going to look a heck of a lot nicer than mine! Those parts look perfect! Keep up the good and fast work and you'll have the forward fuselage finished in no time!
