Symmco bushings
Sun May 17, 2020 12:56 pm
by Carlos Trigo
Guys
I am having a difficult time finding the exact bushings called for in the plans.
It seems ACS doesn’t have all the needed references, and I am not able to find them.
Where did the crowd go to source for these bushings?
Carlos
Re: Symmco bushings
Sun May 17, 2020 1:14 pm
by sonex1374
Carlos,
Wicks Aircraft and McMaster-Carr both carry various straight and flanged bronze bushings. You can explore their websites to see if they carry the specific bushings you need.
https://www.wicksaircraft.com/shop/flange-bushing/https://www.mcmaster.com/sae-841-bronze ... -bearings/Jeff
Re: Symmco bushings
Sun May 17, 2020 4:41 pm
by rdsafe
Carlos;
I acquired these bushings: 2 ea.- Symmco #SF-610-6 (#EF0305-06) sintered bronze flange sleeve bearing, Symmco #ST-1020-2 (TT 602) sintered bronze thrust washer -
near me at: Motion Industries Inc, 229 NW Wilks Lane #7, Lake City, 386/755-4330 - last year for $5.27 w/tax last October. Of course, I picked them up myself. If I remember correctly, they had to be ordered.
Good Luck,
Richard Stauffer
Re: Symmco bushings
Mon May 18, 2020 8:49 am
by inventor
I get my bushings at MRO Supply:https://www.mrosupply.com/bearings/non-rolling-element-bearings/sleeve-bearings/
You might have to buy $20 worth but that gives you free shipping too.
Re: Symmco bushings
Mon May 18, 2020 5:20 pm
by Spaceman
If I remember correctly I had to get a few bronze bushings from Mcaster Carr since ACS didn't have them. There were also a couple that I remember having to buy slightly long and then filing down to the correct length, which was tedious but it worked.
Symmco bushings
Tue May 19, 2020 6:48 am
by Carlos Trigo
Spaceman wrote:If I remember correctly I had to get a few bronze bushings from Mcaster Carr since ACS didn't have them. There were also a couple that I remember having to buy slightly long and then filing down to the correct length, which was tedious but it worked.
By any chance you don’t have a list of bushings needed?
Or anyone else?
Thanks
Carlos
Re: Symmco bushings
Tue May 19, 2020 7:53 am
by Kitfox93eg
The McMaster part number is 6338K411 like others have posted you will need to shorten the bushing for proper clearance. The plans call for 5 to 15 thousands side clearance I used a lathe but a file would work also.
They also had the bushings for the B control stick that number is 6338K421
If you have never used McMaster Carr you need too they have everything.
Ed Grasso
Re: Symmco bushings
Tue May 19, 2020 8:17 am
by Kitfox93eg
Carlos, if you want I can run some off on my lathe and ship them to you. Just let me know.
Ed Grasso
Symmco bushings
Tue May 19, 2020 10:43 am
by Carlos Trigo
Kitfox93eg wrote:The McMaster part number is 6338K411 like others have posted you will need to shorten the bushing for proper clearance. The plans call for 5 to 15 thousands side clearance I used a lathe but a file would work also.
Ed Grasso
Ed
Thanks a lot for your offer
I am going to try to figure out, from my list (which can be wrong), which ones I am not able to source, and come back to you if I need.
By the way, are these bushings made from plain bronze rod, or are they a special “oil impregnated” material?
Carlos
Re: Symmco bushings
Tue May 19, 2020 12:24 pm
by Kitfox93eg
Oil impregnated
