L01
L01
Postby Sonex374 » Mon Jul 13, 2015 8:45 am
Inserting the dual control stick assembly in fuselage I have about 3/16" between the stick assembly and the mounting angles, This is about 2 waskers needed on each side. Has anyone run into this before? I used matched hole parts so the locations were set by that.
Rutter
N374WR (Reserved)
Sonex tri-gear
Polish
Aerovee
Sonex374
Re: L01
Postby rk2436 » Mon Jul 13, 2015 10:25 am
Perfectly normal. Just add washers .
Bob K
Orig builder kit 1143
Now flying RV-12
Evergreen Park,Il
rk2436
L01
Postby Sonex1517 » Mon Jul 13, 2015 10:47 am
I ran into this also. As stated, just add washers as needed.
325+ hours
Re: L01
Postby Rynoth » Mon Jul 13, 2015 1:02 pm
Actually a nice perk of this fudge in fitment is the ability to slightly locate the control stick left/right (using washers), which might help to get the stick-to-idler pushrod to fit down the center of the seat pan (with a lowered seat mod the clearance is pretty tight for that pushrod.)
Re: L01
Postby Sonex374 » Mon Jul 13, 2015 2:25 pm
Thanks all for input!
Rutter
N374WR (Reserved)
Sonex tri-gear
Polish
Aerovee
Sonex374
Return to Sonex Plans
