Fuel level sender
Fuel level sender
Postby crwallace1 » Tue Aug 01, 2023 4:26 pm
I’m planning on installing a Dynon HDX. What fuel level sender will work with this?
Waiex B
Slow build
Standard gear
Jabiru 3300
N333YX reserved
crwallace1
Re: Fuel level sender
Postby karmarepair » Tue Aug 01, 2023 5:45 pm
I think Sonex is selling the RED sender (formerly Princeton) that will work with any engine monitor. Or you can buy one from RED or AS&S.
karmarepair
Postby pappas » Wed Aug 02, 2023 10:02 am
I can verify that the RED, formerly Princeton Probe, will work with the Dynon HDX. That is what I had installed in my B Waiex.
Lou Pappas
Phoenix, AZ
RV-7A (Building)
Waiex B Turbo
RV-8
Waiex Legacy 3300
Hiperlight SNS-9
Falcon Ultralight[/b]
pappas
Postby GordonTurner » Thu Aug 03, 2023 12:13 pm
CR Wallace
I have the fuel sender unit from Lou Pappas’ Waiex. I’m building an A, this is the unit for a B.
Contact me PM if you want it for the shipping.
Gordon
Postby pappas » Fri Aug 04, 2023 6:08 pm
Awesome you guys could get together!
Lou Pappas
Phoenix, AZ
RV-7A (Building)
Waiex B Turbo
RV-8
Waiex Legacy 3300
Hiperlight SNS-9
pappas
Postby Skippydiesel » Wed Aug 09, 2023 4:13 am
pappas wrote:I can verify that the RED, formerly Princeton Probe, will work with the Dynon HDX. That is what I had installed in my B Waiex.
Hi Pappas,
I have a Sonex Legacy (metal fuel tank) / Dynon Skyview - I am contemplating fitting the RED (Princeton) Fuel Probe - please tell me of your experience/opinion.
I have heard it is super sensitive to any water collecting around the probe base/lowest point in fuel tank - have you had any issues?
Also;[list=]
I tend to only use ethanol free ULP BUT one never knows for sure that some cross contamination may have occurred - your comments?
Flying in Australia, may mean that on an away trip, I may occasionally have to efuel with AvGas - your comments?[/list]
Skippydiesel
Postby karmarepair » Wed Aug 09, 2023 12:26 pm
The dielectric constant shouldn't vary much between ULP and Avgas. I found the probes and probe wires a little less than robust, but once it's installed, they seem to be bombproof. Ethanol will raise hell with the calibration. If one has to run ethanol containing MoGas, I think it's use a fuel flow meter and a totalizer. The service experience of the Belite Radiant hydrostatic pressure gauges doesn't look very good. And unless your panel is designed to use a sight glass, that option is right out.
karmarepair
Postby pappas » Wed Aug 09, 2023 1:46 pm
I only use AVGas in my aircraft and live in the Phoenix, AZ area. Very dry here. Since moving here I have never had issues with water in my fuel. The instructions from RED/Princeton recommend that you do not use water to calibrate the probe as it will give you different readings than fuel. So, just calibrate it with fuel. If it gets wet from water, just make sure it is completely dry prior to calibrating with fuel.
Remember that water is heavier than fuel and will seek the lowest point in your fuel system. If you have a gascolator water will settle there and you will drain it prior to flight. I did not use a gascolator in either of my Sonex's and had no issues with the Aeroinjector passing any water that may have been there, ( I never noticed any).
The probe needed to be cut and shortened a bit in order to fit in the B model tank according to the plans. I don't remember if it needed to be cut for the Legacy model. Cutting and calibrating was no problem, I simply followed the written instructions and all went as expected. I also used the same model probe in my first Waiex, a legacy model, with no problems whatsoever. I would use it again without concern.
Coincidentally, the RV7-A I am building has the Van's capacitive plates in the tanks and the sending unit that we use for those is also the Princeton/RED modules. I like having the capacitive measuring devices but still rely mostly on a calibrated fuel flow sender for the most accurate indication of remaining fuel and flight times.
Lou Pappas
Phoenix, AZ
RV-7A (Building)
Waiex B Turbo
RV-8
Waiex Legacy 3300
Hiperlight SNS-9
pappas
Postby Skippydiesel » Thu Aug 10, 2023 4:11 am
Pappas, Thank you for your very full response.
My Sonex Legacy is a tad diffrent to most, having 30L wing tanks, feeding a centre (position of standard tank) 40L "header" tank. It's a header, only because it does not have an external fueling point, being supplied from the wings.
My header fuel gauge (Dynon) & sender (RED?) must be reasonably accurate, so that my finflight fuel transfer management will minimise the chance of overfilling & venting fuel overboard.
Last question: Do you find the RED/Princeton to give good consistent fuel readings?
Skippydiesel
Postby bvolcko38 » Thu Aug 10, 2023 8:44 am
I have an MGL efis with sonex supplied probe. I calibrated with 100ll. Using 90 or 91 non ethanol, my fuel gauge reads about 2 gallons low.
Bill Volcko XNS0068
Aerovee and Prince P-Tip
V6
First hole 4/1/16
First flight 8/24/18
Phase I complete...finally!!!
bvolcko38
Return to Sonex Plans
