ONX-L04 Brake Line Attachment
Discussion for Onex builders on specific plans page experience. These posts are limited to technical suggestions such as assembly order, challenges, or techniques related to specific plans pages.
Postby John Usher » Wed Aug 02, 2017 10:48 am
On Onex plans page ONX-L04, view B-B states as an option to "tape" the cable housing to the gear legs.
For those who have, how did you attach your brake lines to your gear legs?
If possible, a picture would really be worth a few hundred words in this case.
Thanks in advance!
John U.
John Usher
Sold all my toys...
John Usher
Re: ONX-L04 Brake Line Attachment
Postby onex28 » Wed Aug 02, 2017 10:50 pm
John, I bent some .016 2024 around a piece of brake cable to make several "anchors" to hold the brake cable. I then drilled and tapped the gear leg to secure these "anchors". Send me your email and I will take a photo the next time I get to the hanger.
David. Mudywatr at comcast dot net
onex28
Postby dirkverdonck » Thu Aug 03, 2017 3:13 am
Hi,
This is how I did it, the brake line doesn't sit below the leg but behind it, less drag!
I also used low profile nuts instead of these.
Dirk
Onex 117
Dirk Verdonck
Leffinge, Belgium
Onex #117
dirkverdonck
Postby Stogie6 » Thu Aug 03, 2017 7:58 am
John Usher wrote:On Onex plans page ONX-L04, view B-B states as an option to "tape" the cable housing to the gear legs.
Thanks in advance!
John U.
John,
I used zip-ties (saw that solution on a crop duster gear leg) for a temp hold til I get around to upgrading my mechanical brakes to hydraulic. Then I will secure with the proper attachments.
David F. Jones
Memphis (Mud Island), TN
Aerovee powered Onex
N153TD
Based at KAWM and in the midst of Phase 1
Stogie6
Postby builderflyer » Thu Aug 03, 2017 9:14 am
Not a Onex, but on my Sonex I used duct tape that gets replaced every few years. That's for either the cable brake lines or the hydraulic brake lines. Cable ties, if in contact with the aluminum gear fairings, will cut right through them after a while for the same reason they shouldn't be used on an engine mount.
Art,,,,,,,,,,,,,,,,,Sonex taildragger #95,,,,,,,,,,,,,,,,,,Jab 3300 #261
builderflyer
Postby John Usher » Thu Aug 03, 2017 10:27 am
Thank you all for the replies and pics!
John U.
John Usher
Sold all my toys...
John Usher
Return to Onex Plans
