Electrical penetration of the firewall
Re: Electrical penetration of the firewall
Postby Bryan Cotton » Thu Nov 01, 2018 9:50 am
Thanks David! I just placed an order for that part.
Postby Bryan Cotton » Mon Dec 03, 2018 11:32 pm
Here is my cheap penetration installed. I have enough spare firesleeve to seal it up.
Inside:
Postby Bryan Cotton » Tue Dec 04, 2018 8:29 am
One thing I forgot to mention - if you put the fitting in like I did, it protects the wires from the edge of the firewall. I was going to install it like in Ryan's picture and then I had an epiphany.
Postby Rynoth » Tue Dec 04, 2018 11:03 am
Bryan Cotton wrote:One thing I forgot to mention - if you put the fitting in like I did, it protects the wires from the edge of the firewall. I was going to install it like in Ryan's picture and then I had an epiphany.
I like your solution!
For what it's worth, in the ACS kit installation, the wires are protected from any firewall/metal edge contact by wrapping the wires in some of the fireproof sleeve passed through the fitting itself. Besides protecting the wires from chafing, I assume this also helps to make a better fireproof seal on the engine-compartment side (more meat for the full sleeve to clamp onto.) It was done by taking the sleeve and cutting down the middle of it lengthwise to make it a smaller diameter to stick through the opening. You might consider using the same method even in your install. Here's some pics:
You can see in the bottom picture that the outer sleeve is wrapped around the inner sleeve which is wrapped around the wires.
Postby Bryan Cotton » Tue Dec 04, 2018 1:01 pm
Ryan,
I will do that, thanks.
Postby n307tw » Fri Mar 29, 2019 1:28 pm
Bryan,
That looks great, just found out I have to make another penetration in my firewall for all the sensors for the Aerovee Turbo. Garmin doesn't approve of their engine monitor being installed in the engine compartment so I have to bring all those wires into the cabin. I will be doing the cheaper option for this penetration on this one for sure. Both your and Ryan's came out great.
-Tim
Tim Wrede
Long Island, NY
Sonex-B #18, Nosedragger
Aeromomentum AM15, Garmin G3X
My Build Site
n307tw
Postby GordonTurner » Fri Mar 29, 2019 7:05 pm
That’s a lot of orange. Bryan, what was your favorite color again?
Gordon
Postby GordonTurner » Sat Mar 30, 2019 9:57 am
Hi Bryan
Question about your fire wall seeling. It appears you are seeling both the engine side and the cockpit side of each fastener with rtv. I’m sure the protocol for firewalls is spelled out somewhere, do you happen to have an informative but still readable source?
Thanks, Gordon
Postby Rynoth » Sat Mar 30, 2019 1:33 pm
Hi Gordon, I assume you're referring to my pictures above. I actually only did one side of most fasteners, it's just that I didn't seal the nutplates until they were installed and only really had access from the inside of the firewall since the attached accessories were in the way. Didn't follow any real guidance other than just trying to make sure every hole I made in the firewall was made airtight with sealant.
And yes, I like orange. It was a big tube of sealant and I have fat fingers.
Postby GordonTurner » Sat Mar 30, 2019 3:10 pm
Ok. Thanks for all the info, more to think about as I creep up on the firewall forward part of the project.
Return to Electrical System
