racaldwell wrote:One way to prevent voltage sag when cranking the engine is separate the engine monitor from that electrical circuit.
That is what I am doing for my motorglider. I have a separate battery (K2 soaring battery) that feeds the avionics bus that is isolated from the main bus with a switch. The main bus has the starter battery (ETX680.) After starting, flip the switch to connect the K2 battery to the main bus so it can get charged when the engine is running.
In your case, you can use the 2nd battery as a back up. The Lifepo batteries means they are not a weight detriment anymore.
I have a schematic if anyone is interested.
Rick Caldwell
Xenos 0057
bvolcko38 wrote:I would like to see your schematic.
N190YX wrote:When you operate the starter, you have crazy amperage spikes resulting in voltage spikes up and down as the starter is actuated, and then lugs down a little on each compression stroke as it slows down with the load on the compression stroke, using more amperage, and eases up while the engine is not on a compression stroke and turns more easily. I damaged the gas discharge numbers on a KX155 by accidentally starting my engine with the avionics turned on after the engine stalled on a landing roll out. Should have turned the avionics off before using the starter. I recommend turning everything off while using the starter! Those avionics are expensive, to purchase, and to repair!
lakespookie wrote:I also don't see any of the power draw for the engine sensors does the GEA24 module power account for the senders?
My power budget is a little worse than yours not that I need to worry about that for at least a few more years but my average power draw is currently at 18.52 Amps and 28.51 Amps peak(Although I doubt I would ever be transmitting from two radios at the same time so this is actually lower conservatively closer to 25 amps), but I have still not accounted for all the engine sensors. Honestly its a little concerning given how little head room that leaves for charging the battery. Note my power budget is worst case at night when running all the lights and with the exception of the caveat above in general is significantly more conservative during daytime operations. as you can cut 4.5 amps from the average and total power and even at night I would only have this power draw when approaching to land. the rest of the time that's 2 amps removed from the overall loading so I think its still doable
I also currently have a GPS20 A included in the power budget and that will most likely be removable since I want to throw a GNX375 into the system and I belive I would not need the sepreate box for that since the navigator will pump what I need into the system. (My reason for this an not going the GPS 175 route after the fact is mostly price dependent but I budgeted with the swap in mind in case I want to lower overall package costs. but the difference between the GPS175 and the GNX 375 is slightly less than 3k and I like the idea of having an extra entry field for redundancy in case the G3x goes down with the G5 and the GNX I still have transponder control and enough flight data to get around even in the worst conditions).
Other things to note my planned electrical system includes 3 servos, I want to do long leg cross countries so I want to throw in a yaw damper if possible although I suspect that either that wont be possible or I wont find an elegant mounting point for the YD servo so that would improve power budget. My Avionics plan also includes a G5 with a backup battery and the interface unit. YMMV. I probably should worry about building the damn thing before the avionics but I am an engineer by trade and have had about 2 months to think about random things since I ordered my tail kit.
I also would add that most of the Garmin avionics support dual bus power so you could potentially have a completely independent power bus for the avionics. it would take a little more wiring and an extra switch but it would allow you to have an independent power source as a backup, and allow for starting with your avionics switch off while still powering the Garmin panel for engine monitoring. and a fall back bus in case of an electrical system failure. At least that was my plan even though I have the g5 with the battery backup for when I'm in flight I have been bouncing the engine monitoring stuff around in my head as well on startup and that's probably the best solution heck you can probably wire it to cut bus two when the main avionics is on if you wanted true bus isolation but the internal circuits in the Garmin units should draw from the better power source which I suspect in most cases would be the main power bus unless you were really low on your battery.
