I've been weighing the pro's and con's of breakers and fuses. I like the idea of fuses, but want to keep them close to the switches so I don't end up with wires all over the place. One idea is to attach the fuse panel to the underside of the glare shield between the instrument panel and fuel tank. The fuses would be the style that light up when blown.
- BUS_Tns_15600-atc-blade-fuse-panels_220.jpg (10.33 KiB) Viewed 2274 times
Obviously, I don't intend to access them very often, but would like to be able to duck my head under the panel and check for blown fuses and replace them if necessary. Does this sound like a pipe dream? Will the stick prevent me from being able to lean under the panel and look up at the glareshield? Is it just physically impossible without laying on my back in the seat?
Feel free to convince me that CBs are the way to go or that mounting automotive fuses directly on the panel will make my cockpit look awesome.
