by MichaelFarley56 » Tue Feb 18, 2014 4:55 pm
Hello All,
There's been some chatter among other homebuilt aircraft forum boards about what builders have installed in their aircraft to serve as a ground power option. In general, there seems to be two options; first is to install some sort of power plug that has the amperage to actually crank an engine, while the other option is to install a battery tender/charger in order to power up avionics, test wiring, and trickle charge the battery.
When I built my Waiex I didn't include any sort of capability for this, but I'm slowly starting to reconsider with the thought of adding something very small and lightweight to act as a battery trickle charger in addition to the ground power capability. I can see the benefits to this as I've had to pull my cowling two or three times in order to charge the battery during cold months after a lot of ground runs. Personally, given the electronic ignition design of the engine, I'd rather always make sure I takeoff with a fully charged battery!
In theory, this seems like it could be a pretty simple affair. Run some sort of medium gauge wire from the positive terminal of the battery down to the bottom of the engine mount, putting it in an accessible location through the cooling exit area so I can clip it to the positive clamp of a battery charger. The negative side could be done in the same fashion, or simply by clamping that lead to the exhaust pipe or similar grounding point.
Before I do anything though, I wanted to get your thoughts. Has anyone done something similar? Any recommendations? Has anyone done something similar?
Thanks everyone!
Waiex #0056 - N569KM
Jabiru 3300A #1706
