Herraripower wrote:Kai,
Murray is absolutely right.
A larger bore will decrease your overall brake pressure, a smaller bore will require a little more effort, but much more pressure. On my Sonex I’m using 1/8” line and 1/2” bore Hegars on my Sonex brakes and if I try and land short and apply hard pressure, I have to back off sometimes because my tail will rise and the plane will nose over. They are toe brakes so I am able to apply a good amount of pressure. They do provide adequate stopping power. Differential definitely makes a difference in control and stopping ability. Now I don’t need a parking lot to make a u-turn. Hegar makes a quadrant of dual masters and handles you could install. Also you could install 2 handles on the stick, I say that because my other aircraft with Hegar brakes have them set up on the handle and they work awesome. I just alternate with my fingers and I don’t have to take my hands off any controls. Only difference between the 2 planes is I have Hegar disk brakes on one, and Sonex on the other. Lines and bore sizes are all the same. I would shy away from heel brakes in my opinion. Or, just make some toe brakes!
Skippydiesel wrote:Great stuff Zack. Thanks for all that. Did you manage to work out how to post the pdf file you referred to??
Zack wrote:Next week is exhaust week, I trailered the plane to the exhaust fabricator yesterday. My goal for the exhaust was equal length primaries and a 4-1 merger into a secondary, all at appropriate lengths for engine size, rpm etc to maximize power between 5400 - 5900 RPM range. I purchased a program called PipePRO that allows you to enter the engine characteristics and it would calculate the ideal pipe length, diameter etc. The end result would look like some of these systems: https://www.kitplanes.com/firewall-forw ... t-systems/
Unfortunately the space constraints won't let that happen. The biggest issue is the Sonex bed mount verses the more typical ring mount. In addition to the mount, the radiator and oil cooler are also on centerline. If I wanted to merge the exhaust from each pair of cylinders it would have to happen behind the radiator close to the firewall. This won't leave space for any length after the collector, it would have to drop out of the cowling immediately. I would need to use inline mufflers before the collector. Finally, running the exhaust along the entire bottom of the firewall would add a lot of heat where my ECU, fuel pumps, fuse box etc are mounted. Not an ideal situation.
Thanks to the wider firewall on the B-Model, I do have a lot of room on the sides. We are planning to do a 2-1 design with two exits, one on each side. I considered the sides of the cowling first, but I don't want the exhaust exiting directly in front of the leading edge of the wing, and higher up I have two of Peter's NACA vents and I don't want CO poisoning. So out the bottom it is.
Based on my research, and the PipePRO program, I should NOT step up the pipe diameter after the merger / collector on a 2-1 system like I would for a 4-1. I'll be using 1.2500 OD tubing (the factory exhaust sockets measured 1.1895 OD). The ID is 1.1300 versus the 28mm / 1.100 the Installation Manual calls for. I will try for 11th harmonic 8.8" to 11.9" equal length primaries with 7-15 degree merge angle, then an inline motorcycle style muffler and exit out the bottom between the landing gear legs and the radiator exhaust duct.
The Rotax installation manual states: "Distribution of the exhaust system into 2 separate systems is not recommended. Individual mufflers on either side cause power loss and increased engine noise." but it also says "The shape and configuration of the exhaust system is essentially determined by the free space available in the aircraft.". I'm disappointed there wasn't space for a 4-1 system. Looking back, the only way that would work is if I had ring mount and / or split the radiators, one on each side.
The graphic I shared in the previous post should help visualize this. I'll take photos this week and share later.
Zack wrote:……..The Rotax installation manual states: "Distribution of the exhaust system into 2 separate systems is not recommended. Individual mufflers on either side cause power loss and increased engine noise." but it also says "The shape and configuration of the exhaust system is essentially determined by the free space available in the aircraft.". I'm disappointed there wasn't space for a 4-1 system. Looking back, the only way that would work is if I had ring mount and / or split the radiators, one on each side……..
--- Primary Tube Specs : Race Header • Single Tube diameter size ---
Peak TQ Diameter Range = 1.213 -to- 1.338 Best Length = 32.524 -to- 34.924 inches
Best Mid-Range Diameter = 1.338 Best Length = 32.524 -to- 34.924 inches
Peak HP Diameter Range = 1.338 -to- 1.463 Best Length = 32.524 -to- 34.924 inches
--- Primary Tube Harmonics --- ( One-End-Closed Tube = Odd Numbered Harmonics )
1st Harmonic = 97.573 to 99.973 inches long ... typically never used ( too long to fit any Vehicle )
3rd Harmonic = 32.524 to 34.924 inches long ... highly recommended , best Torque and HP Curve
5th Harmonic = 19.515 to 21.915 inches long ... shortest recommended ( Shorty or very Hi-RPM Header )
7th Harmonic = 13.939 to 16.339 inches long ... shortest recommended ( Shorty, Hugger, or Log Style )
9th Harmonic = 10.841 to 13.241 inches long ... shortest recommended ( Log Style or Cast-Manifold )
11th Harmonic = 8.870 to 11.270 inches long ... shortest recommended ( Log Style or Cast-Manifold )
--- Collector Specs : Straight Tube Collector • or Straight with a slight Merge shape ---
Peak TQ Diameter Range = .923 -to- 1.048 Best Length= 21.312 -or- 42.624 inches
Best Mid-Range Diameter = 1.048 Best Length= 21.312 -or- 42.624 inches
Peak HP Diameter Range = 1.048 -to- 1.173 Best Length= 21.312 -or- 10.656 inches
--- Collector's Harmonics --- ( Both-Ends-Open Tube = Odd and Even Numbered Harmonics )
1st Harmonic = 170.494 inches long ... longest recommended with Mufflers and TailPipes
2nd Harmonic = 85.247 inches long ... longest recommended with Mufflers and TailPipes
3rd Harmonic = 42.624 inches long ... greater Low RPM Torque -to- Peak Torque RPM
4th Harmonic = 21.312 inches long ... highly recommended , best Torque and HP Curve combination
5th Harmonic = 10.656 inches long ... reduced Peak Torque , higher RPM HP gains possible
6th Harmonic = 5.328 inches long ... reduced Low RPM Torque , even though Tuned Length
Best TQ + HP Tuned Collector Lengths= 5.328, 10.656, 21.312, 42.624, 85.247, 170.494 inches long
Worst TQ + HP Loss Collector Lengths= 7.992, 15.984, 31.968, 63.935, 127.871, 255.741 inches long
Collector definition: from the Primary Tube's ending inside the Collector -to- Atmospheric exit point
Note : all Tube Outside Diameters are based-off your Header Tube Thickness choice's value
