by Skippydiesel » Sat Sep 11, 2021 8:44 pm
Hoping to be a Sonex owner very shortly.
Just an observation on Rotax 912 engine cooling.
I have been flying an ATEC Zephyr/Rotax 912 ULS for about 11 years.
Rotax stock, front mounted, coolant radiator is very effecting. The front location angled slightly down, must be receiving a high degree of ram air. Exit air is just into the cowling (no ducting).
The single Rotax oil cooler, is located low down on the firewall, fairly close to the cowl opening. It has no ducting. I assume it just gets a degree of the warm through flow/exit air, on its way out of the cowling. Like the radiator it seems to be very effective.
In winter, I partially close off the exit air, using a shaped & drilled piece of flat aluminium, I call it a fixed cowl flap. The size has been determined by trial/error. This reduces the air flow to both heat exchangers - so that my engine temperatures are within optimum operating ranges. The cowl flap is removed, when day time temperatures are consistently 25 degrees C or above.
My message is this - it seems to me that people overanalyse the Rotax cooling system. The oil cooler in particular does not usually require very special attention/ducting unless you anticipate a lot of long duration steep climbing/glider towing type work (grunt!). The coolant radiator will do it job with just a nice consistent air flow and may in fact require some restriction in cooler months so that the engine can operate efficiently.
