BRS wrote:But was the battery fully charged from the drain of starting? You won't get full voltage untill the battery gets a full charge.
daleandee wrote:I'm going to politely disagree with this. Your voltage reading is showing what is coming out of the regulator. If you want to know battery voltage you will see it before engine start or when shutting down the alternator in flight. At very low RPM your voltage may show what the battery voltage is if the alternator is not putting out more than the battery voltage. But at 2700 RPM you are seeing the voltage the regulator is sending out to the system.
BRS wrote:
Perhaps I was imprecise. When I said 'battery voltage' what I really was thinking was 'charge voltage'.
Users browsing this forum: No registered users and 40 guests
