[/quote]AlexZ wrote:The Sonex at MTOW could use some more HP to improve takeoff and climb. Sonex acknowledged that and came up with the turbo. I'm seriously looking at another engine. Adding the turbo or swapping for a (used)Rotax ULS cost the same here in Europe.
AlexZ wrote:So back to my first reaction in this topic. - Don't do break-in on the ground.
That's what Sonex advises and I fully stand behind that. Also read this https://www.kitplanes.com/the-most-reliable-engine/ especially the chapter 'Engine Break-in or Engine Breaking?'. Note the text under picture with the shroud on an Aerovee.
phenry wrote:I agree that all the Aerovee needs is good airflow to keep the heads from overheating. I suffered with overheating issues for some time before I finally worked it out.
Having addressed all the above issues and still having heating issues that I had to manage carefully when flying, I finally concluded that the bottom mount oil cooler arrangement is a major problem in the air-cooling system.
phenry wrote:If you have an extra hole in the front of the cowl below the plenum that is used to cool engine oil, then this airflow adds extra pressure below the plenum and the differential pressure is reduced.
The bottom mount cooler is more complicated requiring a special oil pump, additional plumbing, and expensive hardware. It can be way to efficient at cooling the oil, meaning oil temperatures are kept too cool and people must block up the cooler airflow to get good operational oil temperatures, especially in the winter.
phenry wrote:The moment I replaced the bottom cooler with a top mount cooler, everything came good. I permanently blocked the bottom cooler air hole and binned all that extra plumbing and the full flow pump.
phenry wrote:Now my heads are cooler, my oil temperature gets up to the correct values. Even here in Australia with our very hot summers oil temperatures are not an issue. In fact, I have about one third of my top mount cooler blocked off all year round.
So my advise is: Ditch the bottom mount cooler.
karmarepair wrote:IF I had built this engine myself, I'd be much more inclined to do it the "Sonex Way". But I did not. The original engine builder did some strange things, and then the engine sat for about 15 years. The massive amounts of white lithium grease they used as "assembly lube" stuck the oil relief piston in it's bore and blew up two oil coolers before the problem was ID'd. This was AFTER an experienced VW aeroengine owner (1000 hrs in a VP-1) cracked the case to look around, and fixed a few things he saw he didn't like. What OTHER surprises does this engine have? I want to find them ON THE GROUND, and I'm prepared to do what it takes to safely run this engine ON THE GROUND.
