Kai wrote:Many ‘Oshes’ ago I attended an engine cooling forum held by the late Tony Bingelis. Among others he stressed three important points….
3)
Cooling air can’t be pressed into the cowling- it must be sucked in by the vacuum created in the outlet area. This means you need to dump your cooling air in a low pressure area created by the cowling.
NWade wrote:This is why most legacy Sonex/Waiex builders have put a “lip”/deflector at the leading edge of the bottom cowl exits. The deflector disrupts the high-pressure airflow along the underside of the cowl and creates a low-pressure zone behind it,
Scott Todd wrote:I thought it would have been higher. 1/2" is a long way in :) But it helps to illustrate the point to other curious builders. Just put it where Sonex recommends and go from there.
Bryan Cotton wrote:I don't know that I've ever seen it posted before.
