Jabiru Propeller Bushings
Postby 142YX » Sun Apr 14, 2013 12:25 pm
The supplied prop bushings that came with my engine have 1/4" ID holes in them, and the Jabiru manual states to use AN-4 bolts to secure the propeller. The Sonex supplied spinner has 3/8" ID holes in them, as does my Prince propeller. What did you guys do.. just open up the supplied bushings to a 3/8" and use AN-6 bolts? If so, what are you using for prop bolt torque? The value stated in the Jabiru manual will no longer be correct.
450 hours and counting..
142YX
Re: Jabiru Propeller Bushings
Postby fastj22 » Sun Apr 14, 2013 2:01 pm
I think you may have the wrong bushings. Mine are for AN-6. You might wish to call Jabiru USA and see if they sent you the wrong ones or can point you to a supplier of the AN-6 ones.
As for prop torque, I used the Prince settings on the label of the prop.
Postby sonex892 » Sun Apr 14, 2013 5:17 pm
1/4" ID bushings is what Jabiru supply. I just drilled them out to 3/8". Cant remember the torque I use off hand I got it off the sensenich site.
Steve 892
sonex892
Postby fastj22 » Sun Apr 14, 2013 6:41 pm
I did get my Jabiru second hand and it had the 3/8 bushings. So I don't know if the original owner drilled them or he got new ones.
Postby 142YX » Mon Apr 15, 2013 1:35 am
Yep.. here it is from page 35 of the jabiru installation manual, calling out an AN4 bolt
I guess i will open up my bushings to accommodate the AN6
142YX
Postby N111YX » Mon Apr 15, 2013 7:30 am
Drill 'em out. It's surprisingly easy. The metal seems soft.
Kip
Jabiru 3300 #1637 and #3035
Dynon D-180
Becker radios
Garmin GDL 82 ADS-B
1050 hours
48 states visited
Based near Atlanta
Also flying a...
N111YX
Postby 142YX » Wed Apr 17, 2013 2:06 am
Ok..
got the job done on the lathe at work. A drill press probably would have worked too, but it was quite easy this way.
I upsized the bushings using the same 3/8", piloted double margin drill bit that i used for drilling my forward spar blocks (the second time :cry: ):
http://www.panamericantool.com/double-m ... s-937.html
The steel was soft, cut very easily.
142YX
Return to Jabiru
