Hi All,
Just returning from CC29 in Leesburg Florida. Started on the building of my own Corvair motor which means dis-assembly and cleaning. Got through that important step, and got the heads and case sent off for the required prep and machining.
If you are building and haven't decided on an engine yet, or if you at least haven't taken a good hard look at William Wynnes Corvair conversion then you owe it to yourself to do some reading.
http://www.Flycorvair.net Corvair College is a pretty unique opportunity. It's a place where you can spend a weekend talking to other builders, from guys just starting out to guys who are flying. You observe people working on their engines in all different stages. Almost certainly you will see builders complete the final assembly and run their brand new motor on the test stand. This weekend there were three of those, possibly four as another was closing in when I had to leave on Sunday early afternoon. Plus you can bounce your ideas off William, listen to his analysis of other motors in the works, and borrow from his extensive collection of specialized tools.
It was the friendliest and most interesting group of aviators I've had the pleasure of hanging out with in a long time, every body is doing stuff. Took my son and his friend, they enjoyed it too.
And the motor sounds REALLY great when it fires up.
Gordon
gturner01@aol.com
