by SonexN76ET » Sat Mar 07, 2015 8:46 pm
On my cowling where the radius is that butts up against the windscreen the fiberglass was very thin. To get mine to line up better with the windscreen I think I may add a little extra material to make it a little thicker. In the meantime, I have a thick piece of silicone baffling material to raise it to the same level as the windscreen. So, I am not sure if thickening your cowling at the radius will help your fit or not.
Also, instead of tape, I clecoed squares of aluminum under the fiberglass at the seems to hold the two halves tightly together.
Good luck!
Jake
