SNX-W14-02 AND -03 LOCATION
Postby sonex1678 » Mon May 04, 2015 9:03 pm
I am a little embarrassed to ask, but could someone please confirm the location of the wing rib spacers for me. It looks like the installation sequence/order is, back to front, the fwd edge of the aft rib, then the -03 spacer (.125"), then the -02 spacer (.032"), and then the spar. The exception would be the locations where only the -02 spacer is used, and it is between the fwd edge of the aft rib and the spar. Have reviewed several builder's websites and haven't gotten a clear look at this, and have seen a couple with only the -02 spacers installed so want to be sure.
Doug
Douglas B Scripture
Sonex 1678
sonex1678
Re: SNX-W14-02 AND -03 LOCATION
Postby Gripdana » Mon May 04, 2015 9:33 pm
Here is a link to my builders page. I can't see it I my phone but you may be able to see it on a larger screen.
http://websites.expercraft.com/gripdana ... g_id=70139
Dana Baker
Scratch Built
First Flight March 8, 2015
Gripdana
Postby Gripdana » Mon May 04, 2015 9:36 pm
I will try to post some photos in the Sonex 1534 photo album later tonight.
Dana Baker
Scratch Built
Gripdana
Postby sonex1678 » Thu May 07, 2015 10:39 am
Thanks for the help. After reviewing the photos and taking a better look at the spar construction, I confirmed that the order is correct. Thanks again.
Douglas B Scripture
Sonex 1678
sonex1678
Return to Sonex Plans
