Hign CHT temps on rear cylinders during climb
Postby sx1094 » Wed Jan 03, 2018 6:14 pm
Been having high CHT temps on the rear two cylinders during climb. I understand there is a mod that can be done to eliminate this problem. Can somebody please share it with me. Thanks for the help.
sx1094
Re: Hign CHT temps on rear cylinders during climb
Postby lutorm » Wed Jan 03, 2018 6:45 pm
I think first you need to determine whether it is because they are running lean or because they have insufficient cooling. What are the EGTs like and what happens to them if you lean a little?
lutorm
Postby sx1094 » Wed Jan 03, 2018 6:59 pm
EGT temps are fine. If you lean at cruise the CHTs rise also.
sx1094
Postby daleandee » Wed Jan 03, 2018 7:05 pm
sx1094 wrote:Been having high CHT temps on the rear two cylinders during climb. I understand there is a mod that can be done to eliminate this problem. Can somebody please share it with me. Thanks for the help.
Assuming you're talking about a VW conversion ... this is a topic of much discussion on this forum. Here's one recent example:
http://www.sonexbuilders.net/viewtopic.php?f=7&t=3695&hilit=aerovee+CHTs#p28305
FWIW,
Dale Williams
N319WF @ 6J2
Myunn - "daughter of Cleanex"
120 HP - 3.0 Corvair
Tail Wheel - Center Stick
166.7 hours / Status - Flying
daleandee
Users browsing this forum: Google Adsense [Bot] and 37 guests
