Postby Rofomoto » Sat May 15, 2021 3:34 pm
I can’t link YouTube videos any more. Anyone else have a problem?
1735
Longassproject
Rofomoto
Postby Bryan Cotton » Sat May 15, 2021 5:06 pm
There are two buttons - youtu_be and youtube. Pick the one that looks like your link. For me it is always youtu_be.
Postby Rofomoto » Sat May 15, 2021 6:22 pm
Thanx Bryan
Corvair smooth today
1735
Longassproject
Rofomoto
Postby daleandee » Sat May 15, 2021 9:52 pm
Rofomoto wrote:Corvair smooth today
Really good numbers on that engine. Appears to be right where it should be.
Great airplane ... but I'm a little biased! 8~)
Dale
N319WF
daleandee
Postby Rofomoto » Sat Jun 05, 2021 12:13 pm
Slowly fly off my 40 hrs. About 17 so far. I’m interested in knowing if other people can trim their aircraft with full flaps to 70 mph hands off? I have to use a considerable amount of back pressure to hold speed with full trim. I have the plans built small trim tap on the elevator.. thanx billy
1735
Longassproject
Rofomoto
Postby WesRagle » Sat Jun 05, 2021 1:06 pm
Hi Billy,
I built my Onex a little nose heavy. I pulled the last 10 pounds of balllast out of the baggage compartment yesterday. I ran out of nose up trim too. I never need full nose down so I pushed the trim lever most of the way forward, loosened the wire nut, pushed the lever full forward, and re-tightened the wire nut. I'll see if that was enough next flight.
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Hummel 2400 w/Zenith Carb
Prince P Tip 54x50
First Flight 06/23/2020
42.8 Hrs. as of 10/30/21
WesRagle
Postby Rofomoto » Sat Jun 05, 2021 8:05 pm
Thanx Wes. My plane pretty much can’t be loaded out of CG. So I don’t think adding or removing weight will do much. I’m going to try pulling power down wind and just put all the trim in then and see what flap addition on base and final do to speed management.
1735
Longassproject
Rofomoto
1735
Longassproject
Rofomoto
Postby daleandee » Sat Jun 05, 2021 9:01 pm
Rofomoto wrote:Slowly fly off my 40 hrs. About 17 so far. I’m interested in knowing if other people can trim their aircraft with full flaps to 70 mph hands off? I have to use a considerable amount of back pressure to hold speed with full trim. I have the plans built small trim tap on the elevator.. thanx billy
Hi Billy,
In my Cleanex I have enough trim (standard trim tab on the elevator) to keep the pressure on the stick neutral up to 20º of flaps. Once I go full flaps (30º) I need just a little bit of back pressure but it isn't much. Might be that you have the CG a bit forward. When you start doing gross weight testing (I used 200 lbs of sand in the right seat) you will notice the difference with the CG shift. The other difference has to do with how much fuel is in the tank. With full fuel I can feel the forward CG ... especially if I'm solo with no baggage in the rear.
Dunno if this helps,
Dale
N319WF
daleandee
Postby Sonex888 » Fri Oct 01, 2021 7:55 pm
Hi ,
New member here and I know this is an old thread but where did you order your titanium legs from in CT?
Were they able to certify that the titanium was annealed grade5 titanium?
Sonex888
Return to Photo Album
Users browsing this forum: No registered users and 19 guests
