Canopy Piano Hinge PIn Removal
Postby austexaviator » Mon Apr 10, 2023 1:07 pm
I am looking for any tips or tricks with removing the piano hinge pin that holds the canopy to the fuselage.
I have been pulling and twisting but doesn't seem to want to budge. I looked to see if there was a pin drilled somewhere but could not find it. I'd prefer not having to drill out the entire piano hinge. what works to pull those out? WD-40?
Patrick
Patrick
Tailwheel Sonex Model A Jabiru 3300
austexaviator
Re: Canopy Piano Hinge PIn Removal
Postby pfhoeycfi » Mon Apr 10, 2023 2:39 pm
Try LPS spray lubricant, that might help. Perhaps try tapping a pin in from the opposite side to get the old one moving.
Peter Hoey
Philadelphia Glider Council
Also built Sonerai IIL N86PH
pfhoeycfi
Postby Bryan Cotton » Mon Apr 10, 2023 2:40 pm
Are you pulling on it with pliers? That makes it easier. Also try with someone holding the canopy half closed, there may be binding all the way open. That's a general piano hinge thing, I would expect it comes out easily.
Postby austexaviator » Wed Apr 12, 2023 8:53 am
Using pliers and tied tapping from the other side. Not moving. Will try with a helper and the canopy partially closed.
Patrick
austexaviator
Postby Scott Todd » Wed Apr 12, 2023 9:43 am
Have someone work the canopy open and closed a little while pulling.
Scott Todd
Postby Bryan Cotton » Wed Apr 12, 2023 11:40 am
Probably a dumb question, but the pin isn't bent over on both sides I hope.
