Nick wrote:Hi I have a new issue. I found a fuel leak on a 1/8" NPT fitting on the side above the fuel tank level probe. I tried removing and replacing plug with several different fuel sealants. So I think its coming from the brass insert itself. Thinking of trying to get a vaccume pump and see if I can get it to suck in some epoxy around the fitting. Has anyone else had this issue, and what was done to fix? All ideas appreciated. The tank is installed. Thank you all!
Nick
Users browsing this forum: Bing [Bot] and 11 guests
