Corvair Engines - B Model
Postby SnakePilot » Tue Mar 19, 2024 3:54 pm
Unless I missed it, I haven't been able to find a conversation about using a Corvair in a Waiex B build.
Will anyone admit to considering a B/Corvair?
Are there airframe differences from the A model that preclude this?
Has anyone built, or know of a B/Corvair engine mount source?
Has anyone built, or know of a B/Corvair cowling source?
Is there a source for a B auxiliary tank?
Lots of great information and engineering theory in this thread to keep the Experimental movement alive!
Waiex B Tail-dragger - 2850 Corvair Project
Coupe Top, Steam Gauges, Center Stick
Aluminum Main & Aux Tank
Fort Worth TX
N44YX (reserved)
SnakePilot
Re: Corvair Engines - B Model
Postby daleandee » Tue Mar 19, 2024 11:13 pm
Deleted as dupicate
daleandee
Postby SnakePilot » Wed Mar 20, 2024 12:27 am
Dale, thanks for your reply and the good information. I did watch several of your videos before receiving your PM. I'm going to do a lot more research with your threads but I also have a lot of history with a Corvair engine in 3 Corsa 140s I owned and a Greenbrier, so love wrenching on that engine!
Fort Worth TX
N44YX (reserved)
SnakePilot
Postby lakespookie » Wed Mar 20, 2024 11:16 pm
http://www.azaleaaviation.com/products/ ... gines.html
Just ran across this site and talking to Bill had been positive I am probably going this route at this point
I am sending him a jabiru tricycle mount so he can probably work out a jig from that, for other b models as the mounting points won't change
Jill's Build Log
PPL-ASEL
Tail = Complete
Wings Closed Out = 02/04/2024
Waiex-B 0054
Panel G3X
lakespookie
Postby lakespookie » Thu Mar 21, 2024 4:33 pm
My engine mount is on the way to be modified and the engine is ordered only big ticket item left is the avionics lol. Snake if you do reach out to bill at azalea tell him jill sent you lol.
Jill's Build Log
PPL-ASEL
Tail = Complete
Waiex-B 0054
Panel G3X
lakespookie
Postby SnakePilot » Thu Mar 21, 2024 7:19 pm
Thanks, Jill.
Anxious to see how the B mount and engine work out. I haven't decided which Corvair format I prefer, but interested to also hear from FlyCovair and Azalea owners about their installs. Cheers!
Fort Worth TX
N44YX (reserved)
SnakePilot
Postby lakespookie » Thu Mar 21, 2024 8:10 pm
I anticipate the performance should be the same 120 HP is 120 HP, granted prop choice has some influence, if you build it all your self the FlyCorvair folks will get you flying at a decent price, if you are looking to purchase a built corvair your options are FLYSPA at around 20k depending on how much of the kit you have them assemble and core etc. vs 13k. for the spyder corvair.
Obviously FWF and other cost add on to that but i am very happy with the price i got on the full kit including engine, FWF, and Prop. Granted until i have it in hand and installed its all up in the air.
I was also able to get an upgraded Alternator at 65 amps which makes me feel much better considering the avionics and lighting i am including in my kit.
Jill's Build Log
PPL-ASEL
Tail = Complete
Waiex-B 0054
Panel G3X
lakespookie
Postby SnakePilot » Thu Mar 21, 2024 10:53 pm
Jill,
Did Bill give you an estimate of completed weight?
Fort Worth TX
N44YX (reserved)
SnakePilot
Postby GordonTurner » Fri Mar 22, 2024 10:35 am
Discussion of this on William Wynnes Corvair Facebook group:
https://www.facebook.com/groups/1117842 ... 7S9Ucbxw6v
GordonTurner
Postby SnakePilot » Fri Mar 22, 2024 11:01 am
Thanks, Gordon. Now... if I just had a FB account to fully take advantage of the WW site. Just too cantankerous to modernize!
Fort Worth TX
N44YX (reserved)
SnakePilot
Return to Other Engines
Users browsing this forum: No registered users and 9 guests
