![FB5F9499-143F-4091-A9B6-F67ABA11C747.jpeg (2.92 MiB) Viewed 126579 times FB5F9499-143F-4091-A9B6-F67ABA11C747.jpeg](./download/file.php?id=3241&t=1&sid=10f92a0f3a0446be1bf8182377fb9da6)
- An EP 915 ECI engine. Normally aspirated, cubic capacity is 1484 ccm, EFI, oil cooled pistons and CR 10,5:1- 120HP@5800 rpm on the dyno.
Well- an explanation for the Rotax absence in Sonex might be that the greatest population of Jabiru is in the US. You also have the option of selecting alternative brands such as Aerovee and other VW-1 aeroderivatives, Corvair, etc. The rest of the world, save Oz of course, seem to favour Rotax: very much so in Europe. This has gone so far that thieves will not steal Jab engines!
What is more; with production of the Jab gen 4 range now in full swing it has become much harder to source main components as cylinders and pistons for the earlier models- and I finally gave up: onwards to Rotax!
For my Sonex A #0525 DS SG, after 550 hrs with Jab which included two top end overhauls, I decided to use the Sonex supplied mount for the 33A engine as a basis for the conversion, and in combination with the ring mount supplied by Rotax. The only components that had to be manufactured were the split radiator setup and two pcs t=12mm flat steel bars, suitably machined and shaped to accept supports and clear engine components, particularily the Rotax starter motor. This will put the Rotax prop flange on the same CL as the Jab, but 35mm further forward compared to the Jab 33A with the shortest prop drive flange on the driveshaft, provided you elect to use the Sonex supplied rubber isolators for the 33A. Lube oil cooling is by a heat exchanger.
Calculations show that the CG will migrate slightly forward compared to the Jab. This is great as I have a 10 gal seat back fuel tank- previously it could only be filled to 75% capacity due to CG issues.
The conversion is well under way now- see the photos. The issues with the cowling are next.
Thanks
Kai
