WaiexN143NM wrote:Hi Kevin,
Are you installing the sonex hyd. Brakes? Mount the heavy steel disc with the allen flush bolts, and i'd use a lock washer with the nylocs, some have reported recently the nylocs coming loose maybe from heat transfer. Did you use some talcum baby powder inside the wheels and tube? Torque it all down it should pull tight. Let us know.
WaiexN143NM wrote:Hi david,
Good to know. Yes we are using the standard small sonex tire. With your bigger tires, can you still use the sonex wheel pants?
Users browsing this forum: Google [Bot] and 3 guests
