mike.smith wrote:Question: which of the 3 AeroVee wires goes on which tab?
sonex1374 wrote:mike.smith wrote:Question: which of the 3 AeroVee wires goes on which tab?
Mike,
The two wires coming from the AeroVee alternator coil attach to the terminals labeled "AC", then the "B+" terminal connects to your battery/capacitor/battery bus. You can ignore the "L" (low-voltage light) and "IGW" (voltage sense) terminals. The terminal identification is not marked on the unit itself, but follows the picture below. There are several similar units sold by different companies that all use the same terminal functions (they are patterned after a John Deere voltage regulator). The grounding is done through the case, so either use a ground wire on a mounting bolt or attach the regulator to an airframe-grounded component.
Jeff
Mike,
Jeff
